- Apr 19, 2012
Whatcha bump for?
got some benchmark pictures yet or what?
I don't want an APU "yet" but as many peeps as we see coming into this forum section, so woefully under-prepared for FX power and heat...more might do better with an APU rig.
RGone...
OS has no bearing on whether a chip unlocks or not.The b55 won't unlock in a x64 os, so thats why I need the 955.
I don't want to get feisty but in this b55's situation it does.
Exactly my point, thanks.Key phrase here might be better worded if it says > My unlocked to b55 will not work in Win 7 64 bit but does in Win 7 32 bit. I am guessing the unlock is working but the unlocked cores are offing the 64 bit's ability to run. 64 bit is a bit more sensitvie in some aspects for sure.
RGone...ster.
I'm not familiar with AMD chips myself these days, but is the PVP turned off in the BIOS?Exactly the chip unlocks, it clearly is at fault but my original statement although needs to be phrased better like Rgone has said, ''The b55 won't unlock in a x64 os'' still stands.
The chip won't work in an x64 environment which is what I said from the start, hence I needed to use a 965.
Anyways I have discovered something from playing with the 965 I'm borrowing in x64 using handbrake, the scaling of the fx4 provides better performance than the phenom II once it reaches higher clocks. In 32bit mode the fx4 struggled in comparison.
Updated graph of 64 bit above.
