- May 30, 2004
Post up the P-States on that chip if it's still at stock clocks. I'm interested in what they are It looks like a pretty low voltage chip.
Title of this thread might be misleading... what cpu is the OP using? if its the one in the signature, then its an intel cpu...
I don't think HWMonitor is completely accurate in so much as I'm pretty sure your cpu fan is not spinning at 4623rpm! if it is... it looks like its about to burn out or something worse...
On my system with latest version of HWMonitor, it reports cpu clocks at 50Mhz above what I set in bios and that's in maximum clocks column. I think a lot of the info in this program are only approximate averages or something like.. no software can be perfectly, exactly & always right, no matter who writes it..
bsod, crashing, freezing, unstable clocks forcing me to raise voltages....
