First off my specs...
ASUS CUV4X-E Coppermine Socket370 rev1.05. BIOS 1005 Beta.
OEM Celeron Tualatin 1.0A.
Anyways... I started off by removing the three red pins. AN3, AJ3, and last but not least AK4. I know you guys reccomend against physically removing the 3 pins. But let me finish...
Next I put the tually in my board and it posted as Intel Celeron@ 667Mhz! By default, the board was running it at 66Mhz. I was surprised it got it right, but my board isn't that old anyways. I couldn't believe it posted on my first try!
Right away I went to the voltage settings and it was at 2.30v!! I was like holy crap, hopw is it running this high? When I went to select the voltage, to my dismay 2.30 was the lowest I could choose from! Highest being 2.90v. Temps were hitting low 60 degrees celsius... My hs/f is good but not at that voltage! So I shut down and let it cool off.
Next thing I had to do was get the default volatage down... So I took my motherboard out and flipped it upside down. Instead of nail polish, or IDE cable wires, conductive paint etc wrapping the pins on the CPU itself.. I just soldered a piece of 40 conductor IDE wire from AM34(VSS) to AK36(Vid25m) on the back of the motherboard. This was soooo easy compared to trying to wrap the damn pins on the cpu, which is what I tried before.
Having done the soldering, I put the board back in and went into the BIOS to check to see what my voltage choices were...! I was shocked... My voltage choices were now 1.25v lowest, all the way up to 1.55v! This was great! I could now choose 1.5v if I wanted. So I put the FSB at 100 and voltage at 1.5v and botted into windows xp. No problems, ran everything... games, prime95, sisoft sandra burn in for hours. Everything was perfect! But now I wanted to overclock... Maximum of 1.55v was not going to get me far at all... Got me to 112FSB but that was it.
So I proceeded to solder another wire to AM34(VSS)... this time it was AL37(Vid2). Having soldered that... I went into the bios and could now select voltages from 1.55v ~ 1.95v! I knew this was perfect.. I am now running at 1400Mhz, 140x10, 1.65v STABLE. I'm going to try for 1450 and 1500. I'll let you guys know how high I can get this chip. Although I'm pretty happy at 1400Mhz.
This was my first mod of this kind ever, and I guess I'm extremely lucky it worked out so perfect. I wouldn't have been able to do it without all the great suggestions in this thread. Thanks everyone.
