- Sep 27, 2017
Saw some settings in the bios that are kinda new to me and looking to push to 4.0 or 4.1 if possible. Was wondering what to do with these settings.
1. PSS Support: ENABLED
2. NX Mode: ENABLED
3. SMT Mode: AUTO
4. Core Leveling Mode: AUTOMATIC MODE
These are what they are by default, should any of these be disabled for higher overclocking?
Edit: Also pretty confused which program is most accurate. I use CPUZ and Ryzen Master to check on speeds and voltages. CPUZ shows my cpu voltage between 1.37 to 1.39 and Ryzen Master shows my voltage pegged at 1.4375. How can they be so vastly different? In the bios I set the voltage to 1.39.
My Rig:
AMD 5 Ryzen 1600x
Asus Prime x370 Pro
Corsair Vengeance LPX 16GB DDR4 3000
Windows 10 64bit
Hyper 212 LED Turbo- Red
EVGA 850w G2L PS
2. NX Mode: ENABLED
3. SMT Mode: AUTO
My Rig:
AMD 5 Ryzen 1600x
Asus Prime x370 Pro
Windows 10 64bit
EVGA 850w G2L PS
