Nice, but P95 will stress the system way harder than any game. Try Intel burn test for a more reasonable OC stability test.
Yup. Matches what I got on the Wraith Spire. Good stuff to see it's more common than just my CPU that does [email protected]. OP, even a CM 212 Evo shows a healthy temp drop over the stock cooler. Somewhere in the realm of >=10C. Get a decent cheap cooler to reduce the temps, and either enjoy a cooler room, or more room to OC!I'm glad the ASRock motherboard is working well for you. Good overclock on stock cooling by the way.
With my CPU fans on bottom speed my max cpu temp is ~65C. At full speed the temperature actually peaked up to 72C as the cpu firmware decided to up its cpu speed from 3.95 ghz at 1.4 volts to 4.018 ghz at 1.42 volts... However, discounting that, at full fan speed the CPU temp seems to stick around 63C...
