- Dec 19, 2012
No overclock, I did have to bump the ram voltage up from 1.5V to 1.55V for the system to be stable with 4GHZ for CPU and 1.6GHZ for ram.
You set up for F@H mostly don't you whitehawk?
I'm using a V6GT on a FX-8350 with temps under 40c max load running Folding @ Home
Ahem
Don't think it really matters since Whitehawk is going for stability not performance. It still holds true that the OP is going to need good cooling for his 9370.
that "slight smell" post bothers me.
did you remove the plastic from the bottom of the heatsink?
the ulta psu, if it's like mine it's multi rail, besure the cpu and gpu are not on the same rail.
go into bios and reset to defaults and see if that clears it up.
