Oliver297
- Nov 29, 2012
- United Kingdom
I'm going to try and title this so anyone can skip to different parts if they have an answer to my problem, Thanks in advance.
Introduction to my problem
So this is the second time this has happened to me, The first time i was somehow able to fix it but i either can't remember how or seem unable to fix it properly this time.
What happens
Basically when i hit the power switch the system seems to start up normally except the GPU fans start then stop, only one of my case fans power up and the CPU_LED light comes on. I had this problem with the previous Sabertooth 990fx mother board i bought but somehow found a way to fix it, unfortunately it doesn't seem to be as easy this time around.
Specs
Sabertooth 990 fx Motherboard
Gigabyte Radeon HD 7970 Oc'd edition GPU
AMD-Fx 8150 8 core processor
Stock cooler compatible with the processor
Corsair 400R case
650W Corsair Power supply
16Gb Corsair Vengeance RAM 4x4GB DDR3
500GB HDD
1TB HDD
I've tried the following:
Inserting RAM into each individual slot (Used all 4 in all slots 1 by 1)
Re-seating the Processor and CPU cooler
Cleaning the ends of the RAM and the Ram slots
Resetting the CMOS using the jumper
unplugging both HDD's to try them individually
Checking the wiring for any loose wires / broken wires
Checking to see if i'd mistaken any wires for something else
All of these have proved no success , I've seen a lot of forums say the motherboard may need flashing but it came with the BIOS version 1102 which according the the ASUS website should support my processor.
I have further researched this to find changing to a better BIOS version fixed a couple of peoples problem, but it doesn't post so i can't flash.
The only possible problems i can think of would be that the processor is faulty, the motherboard is faulty or i am missing something.. I have already sent back one of the same motherboard due to it being faulty.. It did the same thing when i got it but eventually after i messed with things booted fine and worked for a good 3-4 weeks before just straight up dying.
If ANYONE has encountered a problem like this and has found a fix i'm willing to give anything a try, Again, Thanks in advance.
What im planning to do next if no one has my answer
I'm going to invite my friend over who builds PC's for a living to check it over to see if I've gone over something / Missed something that could be causing the problem or just to check if the mobo / processor is faulty itself.
If that comes out to nothing, I've decided i'll take it to a shop and have them flash the bios for me to see if that works.. If not i'll have to RMA the board which to be honest isn't that appealing since that last mobo (same one) also seemed to have problems out of the box. After reading countless forums i'm pretty sure its just the 8150 and the 990fx bios version [Hopefully]
What happens
Specs
Corsair 400R case
500GB HDD
1TB HDD
