I'm running an ASUS Maximus Formula (bios 1004) and trying to max out my overclock on a QX9650. When I stress test the machine using prime95, I'm getting either rounding errors or fatal errors only on Thread 4, which seems to correspond to CPU Core #4.
I can get the CPU stable at 3.4 GHz and 3.6 GHz with a 400 MHz FSB, but when I try to go to 3.8 GHz, it's always Core #4 that fails after about two hours.
Have you guys seen that the same core repeatedly fails stress testing after a few hours? I think I was 10 hours prime95 stable at 3.6 GHz and 1.26V, but I can't get that kind of stability on Core 4 even with 1.36V.
Anyone have a suggestion on what might be going wrong or any BIOS setting that might help with the same darn core failing after a few hours of stress testing?
Thanks in advance!
Thanks in advance!
