- Jun 7, 2011
Shocking stuff what i read on that german site. The article isnt that old, few months only and does include actual generation it seems.
http://www.gamestar.de/hardware/ssd...sie_daten_auf_ssds_richtig,355,2482970,2.html
The issue is, even after using secure erase or many other overwritte tools, there is still many data previously stored still visible, especially on a SSD. Its even harder to completly erase on them than on HDD they say. I cant personally judge because im not a expert at such stuff but i feel kina shocked reading this. Since i do in no way want to give my data out of my hand in term i have to use warranty (i just dont know whats gonna happen with). Old plater im first gonna overwritte with 0 and 1,and then im gonna destroy it physically because there is simply no accurate way to get ride of it, there is always signs of old data. The only secure way is truly
, simply no joke even if it looks like. Or simply personaly throw a drive inside a incinerator, then its 100% deleted. But i didnt know that a SSD is even more insecure, that article is shocking and it does aswell verify my issues i had, that they in fact, even as a secondary drive, cause instability of the OS, because of stored bits which is hard to get ride of. Only when the power cable or PSU is shut off, it can be taken out.. in many cases. And only the "upper surface".
I try to find english stuff, but the most important infos are always rare on the net. Most is simply nonsense and guessing.
In the study the said, that they tested 12 SSD systems and the erase unit command only was able to delete the data of 4 of those.... four of those! The others still had many old data left the scientists said.. they was able to restore many data!!!
Now whats a alternate way, instead of warranty? Nothing.. Because when flash is used in order to get ride of the issue, users always should keep in mind that there is no warranty in term the flash failed and in fact, ANY WARRANTY WILL BE LOST AFTER. So the entire matter is a huge issue.
Most people are aswell not gonna flash a BIOS unless the PC is malfunctioning, because there is a risk of completly busting the PC, the risk is ALWAYS here, even if many cool youngster deny that fact. A working PC never needs a flash. Any kind of issues caused by it is NOT COVERED by warranty. Although, companys are providing the tools on "how to lose warranty" and im sure they do that with a smile. Stuff like that should be used when warranty is over.
Some other user say, and i totaly believe him because of own experience, that it does absolutly not matter about the endurance of NAND because when a SSD gets defective its usualy because of a defective controller. Many SF drives of that generation had those even out of the box. And when a SSD gets defective, and its only the secondary drive and not OS drive, in term the SSD does interrupt the OS, it can cause freeze and it can stay like that unless the SSD will lose its power. Because every SSD at the start of the OS will get aligned to the OS and TRIM command will start to run, and that moment the SSD, no matter where its located, can crash the whole system. Thats why i currently got many stability issues but only when i download to the second drive, and why it does only happen when i do that, and it even will crash startup unless i do remove the PCs power and completly restart. I soon will get insight of it but it took me lot of time.
So, the most easy stuff to reveal bad controller, is to download huge files on it (even better to DL several at once) and at the same time stream a video (i recommend to stream 10 at once using VLC) using a video player... and i get a failure once every few hours. In the usual daily use, a failure doesnt even appear, when its used as a "game drive", but when there is permannently data traffic, it does truly abuse a controller very heavy and reveal the truth. The load isnt a matter, its to short.. the controller can easely maintain stability at short peaks. When the controller lack to maintain stability it will freeze the OS, finish. Because the SSD controller got to much impact on the OS, it cant maintain stable condition with. The OS is permannently in communication with the drive and if that drive malfunction, so does the OS. However, for HDD it only happens on a OS drive because a HDD is only dependant on critical stuff when its storing OS data. The SSD however, is always attached in a critical way.
User are indeed labor rats, because they (the company) knew exactly that theyr products wasnt fully stable... they knew it! And testers, what do they test? They test peak peak peak... for which they are perfectly tuned for, short peaks. But how is theyr stability for media and excessive endurance? Rarely ever tested. The M4 seems to pass that test, the Vertex doesnt. Now, from the current generation, i can only recommend the M4, sadly. I want to stay as neutral as possible, so i only rely on personal experience, and i personaly own or owned those drives i am talking about. So its not like i am taking a certain political position here, just science. Ofc i feel like many bucks wasted but i have warranty and until yet i didnt have issues making use of it, still. So all in all i cant purge someone else for that matter.
Besides of OCZ or any other manufacturer says that theyr secure erase is secure, i only gonna believe them if they personally was delivering theyr drive to a scientist who is independant and is spelling out nothing but the unbiased truth.
