I've setup a secondary PC to be a dedicated folder, and I've gone with a used i7-920/ASUS P6T and a new Corsair H110. I installed a HD7970 as a GPU. I've built in in an Arc Midi case, using NF-S12A for case fans and NF-A14s as push on the H110. It's currently running 4.0Ghz overclocked.
Thing is, I think the H100 is too loud. This is very apparent since my man rig (also overclocked) just got updated to the same cooler/fans, a 3770K w/P8Z77-V mobo, and is very quiet.
I see two factors: The 920 is hotter due to a higher TDP. Also, in the Arc I had to use the fan controller for case fans only, and the NF-S14As are plugged into CHAFAN1 and 2, which are 3-pin non-PWM plugs, presumably running full speed. (In my main rig they are both connected to the 4-pin CHA_1). By the way, the Pump is connected to the 4-pin CPU_FAN.
I seek advice on quieting down the fans - how can I, and what will happen to my temps?
