- Jan 5, 2004
- Denver, CO
Sentential said:Yea I know.... they need to fix that crap. its annoying
Maybe Memtest 1.6 fixed that?
On topic, those sticks are amazing. I bet you would do some serious damage with an x850 or 7800GTX.
Ross said:Thanks for the info Sen. Is the 3:5 divider only available >300FSB? Until they put out a BIOS that enables the lock free on other chips in that board, I am going to be stuck at about 260FSB.
I have been looking for other 6400 modules with similar latencies...so far Mushkin is looking like the best in that dept. I am tempted to order a pair directly from them. How long did it take to receive yours?
Thanks for the info and thanks for breaking me out of my Corsair "tunnel vision"
whozyodaddy said:So is this in? I have all my parts for my P5WD2/640 setup except DDR2 ram. I've been looking forever. Either this or the OCZ EB... what would you recommend? 5400UL is out of my range.
Yes Ive seen a very large jump in lobby, even without using LOD I bested my previous score by 1k. Observe:hawtrawkr said:have you noticed any jumps in 3dmarks or games? has it done anything for superpi times?
Mushkin has 130+ sets ready to go. So ya, they are in stock. I personally would reccomend this over anything. So far its the best clocking stuff on the internet.whozyodaddy said:So is this in? I have all my parts for my P5WD2/640 setup except DDR2 ram. I've been looking forever. Either this or the OCZ EB... what would you recommend? 5400UL is out of my range.
That is correctSurfrat said:Normal Free Shipping took me 3 days to get mine!
I think Sent overnighted his
hawtrawkr said:could some of the score diffrence there be from the 2 diffrent cards/drivers used or the diffrent clocks on the cpu/system? one side says it has lod tweak and one says it doesnt is that just a mistake?
sorry just trying to narrow it down a bit more. when id use the same hardware and the same clocks on the cpu with higher ram ratios id get almost identical scores as running it 1:1 thats why im wondering if some of the other diffrences in those 2 runs could factor into the score diffrence here or if it was just me.
The balance is more imporant. This stuff does poorly with 4-2-2. Very poor infact It acts alot like TCCD in that sense. Would you prefer DDR400 2-2-2 or DDR550 2.5-3-3?amer1337 said:does it matter that the timings arent as tight ? or is mhz more important then timings.
Sentential said:The balance is more imporant. This stuff does poorly with 4-2-2. Very poor infact It acts alot like TCCD in that sense. Would you prefer DDR400 2-2-2 or DDR550 2.5-3-3?
Same thing here. 710 4-2-2 or 1026 5-3-3?
I'd be interested in that too. Of course the faster memory speed is going to show much higher scores in pure bandwidth tests, but I'd like to see how much of a gain you get outside of those tests.would it be possible to get a 01se compare with your highest obtainable fsb with the memory then one with the same system/drivers etc with the memory running 1:1 to see the diffrences the extra memory clock gives?
johan851 said:I'd be interested in that too. Of course the faster memory speed is going to show much higher scores in pure bandwidth tests, but I'd like to see how much of a gain you get outside of those tests.
Ross said:I just ordered some too With the ROJAK code (thanks for the tip), it was $229.50 direct from Mushkin, plus free shipping for orders >$100...nice! $70-$100 cheaper than the 5400UL and I'll give up some latency for MHz to save that much. This will be my first time using Mushkin and if they perform anywhere near as well as your sticks, I think it will be a good experience
