- Jul 16, 2004
well i can get into windows with 260 with 3-4-4-10-2t 2.85v....unstable
Ill figures something out.... most likely Ill ebay this on monday once I order my replacement. Either way, this mobo is on its way out.Overclocker550 said:sent, how do you know if its your ram or your mobo that wont go over 280fsb? even if it wont, just use the 10x multi, dont waste time rmaing a mobo that was only guaranteed to do 200fsb. My mobo did 300fsb, this is the highest I tested it so far but CPU-z says I got a newcastle and dual channel wont post. I can get into windows at 2.6GHz at 1.4(overvolts to 1.45) but more volts does not help me overclock higher, it only stabilizes 2.6GHz. I think 2.54GHz at 1.4v was stable. This newcastle sure does not like volts!
thousandLies said:so guys, should i pick up the ocz ddr booster and try my luck with 3v+?
or should i try new ram
BenStark said:Well, with the wonders of my own luck, I have successfully screwed myself.
I can get into Windows with 9x / 285 with stock voltage, but Prime 95 will error instantly, as it will do all the way to 1.60V. I'm down to 9x / 277, for a whopping 2497MHz. Doh. Hopefully it will prime at this, if it doesnt I'll cry. My memory is stable at 285 at 2.5-3-3-8 (if my memory (no pun) serves me right), but cant go much higher. Suckage.
Sentential said:No....Im gonna beat up on this sorry sack-of-**** until I sell it. This is just the way I am on my parts Im sure Ill be happy with CPU #2, which will probly happen shortly after Xmas.
I dont think you understand.....it physically will not POST at 279 with 1T and 289 with 2T. Thats REALLLY low.Optimus Prime said:my msi craps out at 310... so I would say if you are sure that your board cant handle at least 300 it is bunk. As for prime, I think we need to stop using prime here. No offence but it is just gonna drive you crazy. with an a64.
And long and the short of it. I have 2 of the gigglebytes here for testing so I will through my chip in em and see what happens. If the results are good I will post back tonite and let you know.
Sentential said:I dont think you understand.....it physically will not POST at 279 with 1T and 289 with 2T. Thats REALLLY low.
Joe Camel said:im a little lost...i understand when we were running non64s and wanted to get the FSB way up to get more MEM bandwidth, but (to me) mem bandwidth comes from: total CPU speed and mem "FSB".
i say this because with CPU: 247(HTT) x 11 = 2717MHz MEM: 400 (247MHz), im getting almost exactly the
same benchmarks as....CPU: 300 (HTT) x 9 = 2700MHz MEM: 333 (240 MHz)... am i missing something?
