- Sep 16, 2003
- Knoxville, TN
[EDIT] I dunno... lol. Maybe we should sticky this?
she's a stuborn one alright ! if i get more time this weekend i'm going to cook her up againSentential said:Dont feel bad bro. Some CPUs are more stubborn than others. Keep at it, eventually she'll crack (not litererly )
I hope you don't mind sen, I figured it would save some time.Sentential said:Basically you use minimal stable vcore. Lower the vcore to the breaking point. Where programs like Prime95 go for only 2-5 mins. Stable enough for windows to run, but not nearly enough for games.
From there you run a program like CPUburn for several hours. You should start to see results after the first burn. Unlike before where P95 would run for 2-5 mins, it should run well over 10 maybe even an hour.
From there you repeat the process, pushing the vcore lower and lower, until it is within the "acceptable / desired range".
From them you do the reverse. You hold that vcore and start pushing higher mhz in 1 -2 mhz (on the FSB) incriments. Repeating a burn in cycle each bump for atleast 4 hours. You keep doing this until you reach your original speed with alot lower vcore.
The final step is to "reset" your voltage settings to their original levels and push the mhz upward. You will see that the CPU will respond a hellova lot better. Generally speaking you will notice that you have both lowered the vcore and raised your top end anywhere from 150-350mhz.
I do this will all my CPUs and it works wonders. This work unlimited times and so far I havent seen a point where it hasnt helped. Granted it takes awhile, but for some its worth the effort
g0dM@n said:Oh, they take vcore separately? That's pretty hot.
There is a sticky on the memory page.MicroAMD said:how do u burn-in memory? if you cant Super PI at 32mb and then trying to burn-in will it work still?
Hmm , why would core#2 need more V?ewitte said:I'm trying it on my X2 right now. Honestly I don't see much of a difference after a few hours. It did seem to help during my last 24hr session though. I'm putting core2 through another 24hour session. Core1 is running prime because it should already be stable... I just want to see if prime runs the entire time The thing needed like 1.45-1.5v on core1 and ~ 1.65v on core2 to run 2.8Ghz.
Eric
