- May 15, 2010
- Euroland, Denmark
Hey guys,
I just got my Emermax UCCL12. Now before i even get started with the question, i want to explain why i only got 1 and not 2.
Pic of setup:
As you can see the Emermax is placed at the back to exhaust air and im still using the stock Corsair on the other side. This is because i dont like visible LED's from out side the case, and the emermax placed where it is will give ambiant light in the case.
Now to the point.
The Emermax is alot more silent then the Corsair, and works better, which means i am running it higher RPM then the Corsair, but should i match them for better airflow or is this setup fine?
Red is Corsair - Blue is Emermax
Should i match speeds (set down the emermax) or is fine as is?
Pic of setup:
Now to the point.
