CheeseOven
- May 30, 2014
Hello everyone!
This is my 1st post here. I have 2 gpu's in a waterblock. i have 2x 120mm rads cooling them in my haf 922 case. I am also putting a waterblock on my CPU now and I'm adding more rads. A 240mm for the top and a Phobya Xtreme 200mm rad at the front. I am wondering if My EK Pump/Bay combo will runs this through. It has a pump, but it's not strong. it's actually 400lph. Which isn't great. Will i be able to run 2x 120mm rads, 240mm rad, 200mm rad and 3 block (gpus and cpu) with that pump?
Pump/reservoir I have:
http://www.ekwb.com/shop/pumps-and-...umps/ek-bay-dcp-2-2-combo-unit-incl-pump.html
If it ain't strong enough, can i add this pump as it is exactly the same?:
I'd put it halfway through my loop and I'd have 2x 400Lph pumps running. I also don't want to stress my single pump to much, It MUST NOT die on me.
Thanks guys!!! ;D
Thanks guys!!! ;D
