- Jul 9, 2002
- Sotira, Cyprus
Hi peeps,
just been playing with Sisoft Sandra 2016 and unsure if my results are wrong or the default results that Sandra give are incorrect.
Example
In the 'Cache Bandwidth' test the following default results exists
AMD FX(tm)-8120 Eight-Core Processor(4M 8T 4.2GHz, 2.4GHz IMC, 4x 2MB L2, 8MB L3)
2x 8GB G.Skill F3-2400C10-8GTX DIMM DDR3 (2.47GHz 128-bit) PC3-19200 (10-12-12-31 7-41-14-9)
113.369GB/s
AMD FX(tm)-8350 Eight-Core Processor (4M 8T 4.51GHz, 2.41GHz IMC, 4x 2MB L2, 8MB L3)
2x 4GB G.Skill F3-17000CL11-4GBXL DIMM DDR3 (2.14GHz 128-bit) PC3-17100 (11-11-11-30 6-50-14-7)
110.810GB/s
I have my rig configured with the following settings
AMD FX-8370E Eight-Core Processor(4M 8T 4.82GHz, 2.4GHz IMC, 4x 2MB L2, 8MB L3)
2x 4GB G.Skill F3-17000CL9-4GBXLD DIMM DDR3 (2.40GHz 128-bit) PC3-17100 (10-12-12-31 7-41-14-9)
99.779GB/s
So whose results are out of line,
mine or the Sisoft Sandras ??
Cheers
- EDIT -
Bumped the CPUNB to 2600mhz (from 2400mhz) very little change new result is 101.166GB/s
So spec wise am totally destroying the default Sandra configs except for the score ......
Example
113.369GB/s
110.810GB/s
99.779GB/s
Cheers
- EDIT -
