- May 11, 2014
I bought a GTX 970 and have had it for a few days, card's amazing and everything seemed fine. However, there is a small problem - if the card is overclocked then in some games the core clock will suddenly drop drastically and the only way to reset it is to reboot my computer. It seems that it happens in games/area's that cause the GPU to drop into very low usage (%).
Here are two instances: 1) Wolfenstein: New Order - the game has a unmovable 60fps cap, I have everything at max graphics and when I'm an indoor environment the GPU usage drops to around 25% then the clocks drop > reset PC/remove overclock. 2) Wildstar - Ultra High preset, caps FPS at '100' and again, indoor environment > clock drops to 560mhz (roughly).
Obviously I realise it's not a huge deal, the games are running so well for the most part that an overclock seems overkill, there are a couple of reasons though. In certain circumstances I see the FPS drop to 50 in Wolfenstein in very intense scenes and obviously an overclock would help close this gap. However, clearly I can't just it on as if I go into an area where my FPS rockets and thus usage dips (due to fps cap) then my card essentially falls to its knees.
Things I've tried: Forcing constant Voltage, forcing constant clocks through 'K boost' and removing the overclock (only thing to work, as stated I'd like to find another route).
Any thoughts and suggestions would be greatly appreciated.
