- Jul 20, 2002
- Newnan, GA
Ok here's the situation.
I have two computers, one laptop and one desktop. And I have a wireless router. Both computers normally use the wireless connection to get on the internet.
Laptop Specs
AMD XP 2200+
768MB DDR
40 GB HDD
10/100 NIC
Wireless Card
Desktop Specs
AMD 64 3200+
512MB DDR
120 GB HDD
10/100 NIC
Wireless Card
DVD Burner
Now basically I'm creating DVD sized files on my laptop and I want to burn them on the desktop. I figured out quickly that wireless is to slow (which I can live with). So I figure I'll just directly connect the two computers throught the router so I can transfer the files faster. Both cards are 10/100, the router is 10/100, and the cables are rated for 10/100. I'm using FTP to transfer the files from the laptop to the desktop. I'm using SmartFTP as the client and GuildFTPd as the server. Normally, I transfer with the laptop not plugged in.
My problem is that I never transfer more than 1.5 MB/second. Since I know that the max for 100Mb is 12.5Mb/second I know I'm not even close. I don't know what would be causing this.
I've checked everything I can think of. I forced the cards to 100Mb and still the same. I thought that maybe since it was a laptop the HDD just couldn't put out 12.5 MB/sec.
Benchmark plugged into AC
Full Image
Benchmark on battery
Full Image
It should still be able to pump out enough to go full 100Mb. The only other thing I can think of is it's software based. Any ideas?
P.S. I ran the benchmark at work and I noticed the diffrence in speeds so I'll try it plugged up when I get home. But still it should be able to do it, right?
Laptop Specs
AMD XP 2200+
768MB DDR
40 GB HDD
10/100 NIC
Wireless Card
Desktop Specs
AMD 64 3200+
512MB DDR
120 GB HDD
10/100 NIC
Wireless Card
DVD Burner
Full Image
Full Image
