- Nov 19, 2007
- San Jose, CA
Hi guys!
Well I recently bought a Samsung LCD HDTV 40" 1080p tv I use to play with my xbox but I want to also test it out on my computer.
My computer has 2 DVI ports (from the 8800gt 512).
My monitor has 3 HDMI ports avaiable and 1 VGA port, but I heard if I just connect a VGA from my computer to the HDTV it will look not so good is this true?
If I get a DMI to HDMI converter, do I need to perchase another DVI cord, and then just run at the end it hooks up to a HDMI adapter?
Thanks
PS: Is there a way to check the resolution on the monitor? It says its 1920 x 1080 but can I see that anywhere?
Thanks
