- Sep 23, 2001
- In your head (Ottawa.Canada)
Hi All,
I got my Gigabyte Ga-Z87x-Oc today and might have made a dumb *** mistake.
First off...are there pins in the socket or are they woven and flat?
The problem:
I took off the socket protection thingy while trying to judge whether my cooler master evo 212 would fit in the new InWin Dragon case (it does not sadly), while replacing the plastic thingy...I tried putting it under the latch instead of on top (forgot how it fit)...I finally figured out it was supposed to snap on top of the socket but at that point I noticed the pins or weaving underneath. The area on the bottom right look like they might be bent a tad. Does anyone have any experience w/ socket 1150 and how pins look? Are they spaced slightly differently in the bottom right? I took some photos to get a better look but it does not show in the photos. I am not sure if I am being paranoid, the lighting is playing trick on my eyes or could I have really bent a pin or two..and if so..how do I fix it.
Excuse my dumbassery...its been a few years since I installed a CPU and first time w/ Socket 1150
The problem:
