- Nov 5, 2013
- Ottawa, ON
- Thread Starter
- #21
did you check with a stock cpu heatsink and fan? Perhaps the waterblock mounting could be causing issues.
Yeah I've been unable to hook up ANY heatsink or fan to it. What's wierd is you get the connector over the pins exactly as it should be, you put mild force on it and it doesn't move and it's exactly the way it should be. You put moderate force and ditto, any more force and you'll bend/breakthe pins. The pins aren't moved or bent in any way,shape,or form either it's a mystery.
I took off the waterblock completely so it isn't the waterblock mounting unfortunately. I think I'm right that it's motherboard, perhaps when he did that he fried or started to fry the motherboard. But again, I've never seen a dead motherboard turn on before. 99.9% of the time it's totally dead.
