- Dec 19, 2012
You're right RGone there's no tab on that and I remember wondering WTF it was when I built mine. I was tempted to use it for that little screamer fan till I noticed it wasn't a fan header. But you did notice! It's the right size for one and in a common fan header location. I thought it might be for testing or diagnostics and assume it was for ASUS only since there was no info in the manual about any jumpers in that location.
That is strange, maybe there's a problem with the board. Like a bad connector I mean. Could be shorting out somewhere, would there be anything behind the board touching it there??
EDIT: I would check the backplate for the cooler make sure it's not grounding on something, also I'm not familiar with that model but I do know if some of these blocks are over tightened it can cause shorting issues.
