- Dec 31, 2011
Hello,
I have a AMD system running okay so far. Its the system on my signature.
Yesterday, I noticed that my NB heatsink was wiggling very loose (of course its not a good heatsink anyway) so thought either tightening it or if needed apply some paste on it. But As i pull the push-pins, heatsink just fell away and i noticed that the paste they used was dried as hard as rock.
So, i thought i would rather go with aftermarket NB heatsink and bought this one from local microcenter which looks good. The push-pins it came with was crap and was too small to hold Heatsink through holes on MB,
I grabbed some tiny nuts and bolts and rubber washers from Home-Depot, and fixed the heatsink on MB. (used the springs that came with original push-pins) Its nice and tight, So far so good.
Real issues are now:
1) while doing all above i had taken CMOS battery out as i wanted to start sytem with its stock setting. I put battery back, plugged all the cables and started the system but to my surprise CMOS was not cleared..... my system had same OC setting I had before. means 3.8 Ghz unlocked CPU, manual RAM timing and 1.39 volt. Wasn't taking battery out for about an hour supposed to clear CMOS and put the system back on all stock setting?
2) Then i went to BIOS and select to LOAD OPTIMIZED DEFAULTS, then only my computer came to stock setting. Then when i stressed the computer using IntelBurn test I see that the TDP goes to 83 W (okay as CPU is rated as 80W) but after completing IBT stress it drops to 30W. I had never noticed this low even before overclocking. I know its all on stock setting, cool & quiet, C1E and all green stting are on auto but still just 30W?
Is this something i need to be concerned?
Thank you.
Thank you.
