PM was able to make the correct alignment for the SSD then move stuff over? that is if i understood what was said. i need to move my HTPC to a SSD i have had sitting around for some time.
All you need to do is just connect SSD to any Win7/Vista and format. Then you can image onto it without messing up the offset. That's all I did when I moved my Win7 to SSD.
ok, I know its been said that the WEI is just a ploy to get you to buy more hardware...but here is a small issue I'm concerned about:
I did a firmware update and turned off superfetch/prefetch based on Intels Toolbox suggestions....and my SSD score dropped from 6.9 down to 5.9( what my Samsung spinpoint SATA II 1 TB drive scored before being replaced by the SSD).
Is there anything I can do to improve the performance of the SSD? Was turning off superfetch/prefetch a bad idea? Was the firmware update a bad idea? If so, what should I do?
I know people say WEI is a joke, and it is, but its basically measuring your SSD transfer speed. A 5.9 means something is not right. You can run some of the more trusted benchmarks to make sure. My X25-M gets a 7.7. It might be the partition not being aligned, or it might be that you need to run TRIM. Intel has their SSD toolbox that can do it.
I ran this benchmark 3 times, and I think the scores look rather low.This drive advertises:I use AS SSD myself. Simple and does the job.
If you notice the red text in the test... pciide BAD
I do believe that is your issue. The partition is aligned so your good there.
Now for the pciide BAD issue. Is your BIOS set to AHCI mode? If it is not, do so and recheck..
(That error is your machine is using the IDE driver instead of the proper AHCI driver.)
If it does not correct it:
We have two fixes available off the top of my head.. First is the simplest... Reinstall Windows, making sure the AHCI mode is enabled prior to reinstall... Yeah, this might be your route after you read the second fix.
Second fix is rather technical and not easy for a beginner. I found a tutorial on another forum. Instead of me typing it out. I give credit to Ned Slider over there for doing the typing footwork..
http://forums.pcper.com/showpost.php?p=4125801&postcount=1
I changed those registry values to 0, but still got the same BSOD errorWindows 7/Vista:
Before switching to AHCI, simply change the value of the following registry keys to 0
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Msahci
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\IastorV
Windows XP is more complicated but it can be done w/o reinstall depending on your motherboard chipset. (I did it.)
