- Aug 5, 2002
Well stumbled upon a few SSD's. Well 2 of them I had, got a new one and acquired another for a build. With that I decided to play around with a few tests to really see how this plays out with different controllers and what really the difference is between them.
Now I am only testing on SATA III controllers on my motherboard.
The Chipsets:
Intel® Z68 (B3) (2x SATA III ports, 4x SATA II ports)
Marvell® 88SE9128 (2x SATA III ports)
Now the major difference between these 2 chips, intel is basically unrestricted and will run up to the top of its 6GB/sec limit per port. Though the Marvel is a little more limited, only being able to utilize 1x PCI-E lane. So its faster than a SATA II port but... not nearly the speed of SATA III. Well the pictures will show it.
That being said here we have it below is 4 screens of the 2 tests I ran. And yes I did run the test more then 1 time for each selection as I was making sure the drivers where installed properly and just messing around.
Top Left: Crucial M4 128GB (Intel SATAIII Port)
Top Right: Samsung 840 Pro 512GB (Intel SATAIII Port)
Bottom Left: Crucial M4 128GB (Marvel SATAIII Port)
Bottom Right: Liteon M6S 128GB (Marvel SATAIII Port)
Top Left: Liteon M6S 128GB (Intel SATAIII Port)
Top Right: 2x Crucial M4 128GB in software Raid0 (Marvel SATAIII Ports)
Probably the best of the test was showing that this Marvel controller... well sucks to say the least. Sure it can deliver OK speeds but if you want to do raid on it, or even a moderately good SSD its handy capped and can be big time. I believe newer controllers from Marvel solved this issue. Just a shame that it was only given a single PCI-E lane, it should have 4 (2 per port)
Note: The Liteon model number might be incorrect, its a OEM drive from Dell Laptop, as I couldn't find the specific model on the website I'm not sure what truly the drive is. Though it was manufactured in July 2013.
Anyways was just having some fun with it might as well share
The Chipsets:
