- Dec 28, 2001
- Toronto, Canada
I am also getting machine check exception errors on my computer. Not sure what is causing it. I have found that Adobe Acrobat (just opening it) causes my system to lock up and then display this error but there have been other instances where it has occured so it is not specific to that application.
This has been affecting me for months but finally I want to put in the effort to fix this before school starts and I loose work! I recall a few months earlier running memtest86 for a few errors and getting no errors, but I could try that again if you all think that might be one of the major issues?
Just some background info on the system
Abit AN8 Ultra, AMD x2 3800+, 2 x 512 pc3200 OCZ premier series, Sapphire x700, 300 GB SATA Maxtor, 2 x 80 GB IDE, Enermax noisetaker 480 watt
I am running everything at stock speeds/voltages etc.
If anyone could help shed some lite on what might be causing this stability issue it would be greatly appreciated.
