is there a way to disconnect all those thick usb cables that come with the i/o panel on the front with the power button .. it takes up so much space on the inside ..
Yep, they disconect with a slight pull. After pulling mine in my stacker it made the inside look much cleaner. With a slave psu at the bottom cable managment is needed, removing them work best for me.
