- Mar 27, 2003
- St. Louis, MO
I just read a post by someone who took the motor out of a housing and used to go inbetween two exaust fans. I was wondering if that would mean 2x's the exaust output?
I am having a problem with heat. If I'm gaming or running Prime95 it doesn't go above 50C and the alarm is set to go off at 55C. But when it's idle for awhile, the alarm goes off and sure enough it's at 55 degrees. I'm not sure what the problem is, exactly. I just came home today and the temp was 55C and I'm sure the alarm went off but no one was home. My first thought was that maybe my vid card (9700Pro) was getting hot because of the screen saver (Aquarium) and throwing off heat, thus triggering the alarm. I haven't had time to test that theory yet, so I'm not quite sure.
My second thought was that this is only a symptom of a bigger problem. I'm not sure that I have enough airflow. My case has only one intake and one exaust, two exaust if you count PSU. The fans are Antec LED 80mm's. I bought them at CompUSA and I'm not sure of the CFM that they deliver.
Will stacking two fans at the exaust help the airflow if I used a shroud as described in the other post? I'm waiting for FedEx to deliver my TT Smartfan2 and I'm going to put that on the cpu heatsink, which is a Zalman 5500 quiet cool, made by PC Maxx if I'm not mistaken. I was hoping that this would help my temps a little but if I've got crappy airflow already, it sounds as if I'm only going to be sucking hot air over the HSF. (The direction of the fan as bought was blowing away from the cpu. I tried reversing, removing the duct but no change in temp really so I just put it back the way it was, with duct pointing to the rear exaust fan.)
Does any of this make sense or am I off track? If I have to mod the case in order to put a bigger fan in I will but would like to try out other ways before I go that far.
I've got a P4 2.4 @3.0 and a Antec Lanboy case. Any suggestions would be welcomed, as would theories on why my temp rises when it's idle and nothing running, cept that screensaver. Which btw, does the screensaver come on when the monitor is turned off?
TIA,
Desire
TIA,
Desire
