- Aug 1, 2002
- Michigan
Water block: Heatkiller 3.0 copper base
radiators: 2x Swiftech 3*120 all copper
WC blocks for 470 GTX: EK FC470 (copper base, acetel front)
pumps: 2x Swiftech 655
No aluminum so no galvanic reaction right? nooo.... Read on
For the last 7 or 8 months, my PC (main rig) had a very slow leak. I thought it was just normal evaporation as I never found any water puddle until a month ago. It seemed to be leaking from the pump housing on either Swiftech MCP655 or Koolance 452X2 reservoir and it had been a while so I decided to dismantle the WC loop for the bi-annual flush and check.
The pump mount that held one of the 2 pumps showed very bad corrosion (with lots of white and brown powdery residues), caused by a crack in rubber O ring that was supposed to keep water from leaking past the pump assembly. As a result, there had been a slow leak that connected with aluminum mount that held the pump to the reservoir block. Slow leak over 6 months mean a lot of corrosion had occurred. The mount itself looks OK aside from ugly discoloration but I'd have to do a complete tear down of every water blocks and flush the radiator to clean out any gunk that could have built up.
White powder may have come from water, I got them as steam distilled from stores but brown powder I have no idea where that came from. The only additive I used were PT Nuke.
I'd have to use the original O-ring that came with the pump as it's the same diameter. Just a hair thicker.
If you have Koolance reservoir that supports direct mounted pumps, and it comes with its own rubber ring, check them!!
