I3lackCat777
- Oct 12, 2012
- Knoxville, TN
Ok still pretty new to the whole OC'ing scene but I think I've got what I want out of my CPU but I'm looking for other opinions and have a question of my own. I've slowly moved up and up to 4.7GHz on my Fx-4170 chip, did this by just adjusting the multiplier and the voltage. I've got it to run stable in Prime95 for 1hour (I know I need to do a longer test on it to get a 100% stable answer, but I feel pretty good with it).
My question is the voltage in CPU-Z and HWmonitor read different under full load than what they are set. My BIOS cpu voltage is 1.45 which is a little high from what I've read, the only reason I've put it up that high is while running prime95 CPU-Z and HWmonitor show 1.4v - 1.392v. I've read some about vdroop or vdrop but not sure I get it.
Does this mean I could go a little farther with the overclock or should I stop?
Just kinda wanna make sure this is a safe OC to keep and wont drastically shorten the lifespan of my CPU.
AMD FX-4170 - CPU
Asrock 970 Extreme 3 - Motherboard
Idol temps are 32C - 33C
Load temp is 55C
Let me know if you would like any more info.
Thanks in advance for your replies.
AMD FX-4170 - CPU
Load temp is 55C
