Hay all. Right now I am running my 3.0E at 3.375 with the FSB at 225 and voltages set to auto. I plan on pushing this higher, as I am rock solid here with pretty low temps: 37 low load, 42 high load. If I go high enough, I might need some extra voltage, but the rated specs for Prescots is a pretty big range. If I change from auto, what would be a good starting voltage as a stable base? Thanks!
