Hi All,
Got a bit of a strange problem here..
When the computer is idle .. the CPU Temp sits at around 50 degrees c
When I load up a game (Saints Row 3 / Call of Duty etc)
The temperature rises, as I guess it should due to the more stress the computer is put under, but the CPU fan never speeds up to adjust to this new heat ... therefore the CPU will get to 60-70 degrees + and the CPU fan only spins at 2k RPM ... this obviously causes a problem whereby the machine is getting too hot as the CPU fan is not cooling it down...
Now what I have noticed is if I take the side / front of the case off .. the CPU fan will immediately speed up .. now this happens whether in game or computer just idle .. fan will spin up to around 5k RPM.
Now what is causing the fan to spin up when the front of the case is off? And spin back down when the front is back on?
Why is the CPU fan not spinning up when the case is all closed even though it is getting hotter?
Can bad thermal paste be the cause, should I remove and replace with new? Could it be a bad CPU cooler? But if it was that wouldn't it just not spin up at all ?
Hope someone can help.
Cheers.
Cheers.
