- Jan 3, 2012
Wakirimas Forum Bothers,
I am at my wits end on how approach this problem. I would be greatly indebted to any forum accolytes that can help me with this problem. For reference see my rig sig. I built this system in September 2004 and she has been rock solid through thick and then. This weekend I decided it was time for a thorough cleaning of my rig. I took the entire machine apart and cleaned all of the components using compressed air. It was beyond time and I was amazed at the dirt and dust that I cleaned out.
I also disassembled my heat sink and rinsed it thouroughly. Following that I cleaned off the old thermal paste of the cpu and applied new. I cleaned up all the blades on all my fans with a cue-tip and rubbing alchohol. Following the cleaning reassembled my rig step by step per my K7N2 manual just like I did when I built it. I hooked everthing back up and powered her up. She booted just find and was getting ready to load Windows when she just shut down -turn off completely. I hit the power button on my case and nothing. I flipped the psu rocker switch to off then on again. I tried the power button again and she came on with the same result - auto-shutdown.
I went back through the unit step by step and made sure that all of the connections were right and tight. Everything checked out so I booted her up again and the same thing happened. During the cleaning I did not move my FSB jumpers J10 and J11. I was running at 200MHz FSB. To troubleshoot I moved J10 to Safe Mode (100 MHz) and moved J11 to open (100MHz). Problem solved - she boots and runs stable. I switched back and same auto-shutoff issue.
I switched back to safe mode went into BIOS and reset a the BIOS to defaults. I had cleared CMOS but wanted to be sure. After all of this I have found that J11 has no effect on the issue provided I set J10 to safemode. Anything other than safe mode and I get the same auto-shutoff. The thing I found worrisome is that after the auto-****off I have to reset the PSU rocker switch to off and then on again. I am not inclined to believe this a psu problem because I've never had it before and according to MSI PCAlert4 my voltages seem normal as they always have . The only other thing that I wondered mght be causing this is my Nvidia drivers. A few weeks ago I downloaded the "last" published Nforce2 drivers from NForcers HQ. One or two of the drivers were modified slightly for better performnace. I wonder if there might be something in those drivers that is creating this problem. They worked fine previously and are right now in safe mode. However I never have "re-started" my rig from scratch with them.
My guess is that there is something that I'm just not seeing with this issue. I feel confident that all of my components are in good working order otherwise I couldn't be running stable at 100Mhz FSB. If anyone has any insight, again I would be indebted for your advice.
Sincerely,
Old School Ninja
Sincerely,
Old School Ninja
