- Nov 15, 2011
- SoCal
Hi Guys,
I am building a new rig.
Budget is tight and cannot buy a CD drive to install OS.
However I have a laptop where I already have Windows 7 installed.
I have Windows 7 CD and new key.
I extracted all the executable files from the CD onto my laptop HDD.
Which option would work or will both:
Connect new HDD and my laptop HDD to new rig and boot windows from laptop HDD.
From laptop HDD I can launch the Windows files/setup and install windows 7 onto secondary (new) HDD. Then remove and boot the new HDD.
Or...
Load the files onto a flash drive (roughly 3.01GB) and boot from flash drive and install onto new HDD. (I can probably obtain a free flash drive).
When booting from flash USB do I need to partition the flash USB in any way? Haven't done this before.
I know its a lot of work considering I can buy a CD drive for 20 bucks but I would have to return the drive since the case is a Silverstone fortress and it takes a slot loading drive which is expensive.
Thanks!
Or...
Thanks!
