I just finished my new build, and I have an Xbox One controller I want to use with it. Thing is, windows will issue the USB sound when I plug it in, and the pad vibrates, but the light doesn't turn on and its inputs won't work. Clean Windows 8 install, currently on the Enterprise trial until I move to Windows 10 in a few weeks. Using the same micro usb cable that worked fine on my netbook.
When I plugged it in for the first time, the driver dialogue box popped up, but I guess it didn't work. I followed these steps http://support.xbox.com/en-GB/xbox-on-windows/accessories/connect-xbox-one-controller-to-pc but as far as I can see the controller isn't even in the device manager. I have Asus' motherboard tool AI Suite III installed (I know, I know) maybe that's causing some kind of conflict. Only thing I can think of. But the tool is making it easy to control the swhile I'm stuck on integrated graphics for a while.
Microsoft really doesn't seem to want to provide separate downloads of the driver, insisting the controller must be 'found' first.
Any advice would be appreciated.
