- Dec 27, 2008
The problem is whenever I try to eject a USB hard drive from this Windows 10 Pro-based desktop I get a blue screen.
I've tried two different USB external hard drives and both give the blue screen when I try to eject them.
No blue screen when ejecting USB flash drives, just the external hard drives.
I have tried this on another Windows 10 (Home Premium) machine I own and there is no problem when ejecting the same USB hard drive.
Blue screen error messages says: Driver_Verifier_IO Manager_Violation (vdsnap.sys).
WhoCrashed data from minidump says:
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
fltsrv.sys
fltserv.sys is associated with Acronis True Image. I unistalled the porgram and cleaned the registry with Ccleaner. I searched fro fltsrv.sys after that and it is gone but the problem persists.
I also ran sfc /scannow and it reported finding and fixing a .dll file but this did not fix the problem either.
Any ideas? USB issues are bite and seem to be so common for some reason.
fltsrv.sys
