- Oct 11, 2002
- The Empire State
- Thread Starter
- #21
No. Everything is stock. Nothing is changed in the bios. Trying to rule out hardware first. Games were running just fine, then it started to crap the bed.C - States are disabled?
That's the thing, there's nothing. When it crashes it acts like if I closed the game itself.Anything in event viewer for the crash?
I'll check that tho, thx.I hear ya!
I had an issue like this on my AMD system and i believe disabling C - States solved it.
I dont game on my AMD system tho.
No. I disable those right off the bat.Any overlays running such as Nvidia Geforce Experience or other 3rd party overlays?
Yeah, imma try that again. Tho I already checked the ram with memtest, trying 1 stick at a time I didn't do. Thx.Have you tried one stick of RAM in every slot? Could be motherboard issue.
My coworker just had to rma a 5800x a few months ago, anything is possible!Imma' poo if it's the CPU.
... that rhymed...
I'm hoping it's just the Cpu. I'm keeping my fingers crossed the 5900X will fix the issue so's I can RMA the 5800X.My coworker just had to rma a 5800x a few months ago, anything is possible!
Just try the one stick in each slot while playing the game that crashes the most.Yeah, imma try that again. Tho I already checked the ram with memtest, trying 1 stick at a time I didn't do. Thx.
Yes, XMP disabled. The board will default to 1333Mhz. I tried that and then setting timings/voltages manually.Did you turn xmp off when testing the sticks?
I wouldn't be surprised. I'll find out today if it's the board or chip.I've got my money on the motherboard. $1. After you replace it and verify that I am correct I'll give you my address. I want 100 uncirculated pennies please.
Good one.. I don't know..." Suppose the games won't run on that either? What then?"
