- Oct 23, 2002
- Muscle Shoals, AL
Quick run up to this point...
My 660Ti would detect my TV but wouldn't output any video/audio to it. So I decided to pick up a 210 since they were cheap and I wouldn't have to worry about having multiple display drivers installed. That worked fine in Windows 7, but caused OSX to need over a minute to boot and another 1-2 minutes to become responsive after boot. So I figured I'd pull the 210 and use the HD3000 graphics for the TV. That worked except HDMI audio will only work with the integrated GPU set as primary in the BIOS. So I've ordered a longer optical cable to use the motherboard audio with the integrated video.
Here's where the weirdness comes in. MP4 videos won't play on the TV. I get sound, but no video. I can play the videos on either monitor hooked up to the 660Ti, but the same videos won't play to the TV. AVIs and MKVs will play, just not MP4s. This is using either Windows Media Player or Media Center. MP4s will play using VLC, but the colors are slightly off.
So far I've tried 3 different driver versions; one from Gigabyte, one from Windows update, and the latest driver from Intel. I've also updated all my codecs and tried Quicksync acceleration enabled/disabled in the codec settings.
I'm completely unsure whether this is a driver issue, codec issue, or Windows issue. The way the files will play on the monitors connected to the 660Ti leads me to believe it's the HD3000 that's the issue, but at the same time since they will play in VLC it seems like it might be a codec/WMP issue.
I've ordered a DVI to HDMI adapter. I'm hoping I can move one of the monitors to the display port and get video to the TV through the 660Ti and avoid having to solve this issue. If that doesn't work, I'll need something else to try to correct the issue on the HD3000.
