I just built a new system as follows:
Antec 300w SL300S
Epox 8RDA3+PRO
AMD Athlon 2400+
256MB PC2100
80GB WD HDD, 120GB WD HDD
128MB 8x AGP FX5200
With no PCI or optical drives my +12v are 9.53v - 10.84v, and my +3.3v are 1.58v - 1.68v according to AIDA32. Speedfan shows a +12v of 5.84v and same +3.3v as AIDA32. The +3.3v and the +12v dont show up in my bios. My +5v is 4.99v but it sags to 4.48v when I power the DVD-RW. All this and no apparent stability issues, I can even OC.
So, I have posted this in the forum before about this, and most people are telling me "don't worry about it." But < 10v on the +12v rail is not normal, and I'd rather lay down for a good PSU, than damage the rest of my system.
My budget is $50 - $75, but I would probably spend more if something really caught my eye. I have been looking at Fortran, Zippy, Antec, Sparkle, Enermax and Vantec PSU's.
Bad MOBO, Bad PSU?
What do you guys recommend for a PSU?
Is the Fortran AX500 overkill?
Any thoughts on why my voltages are so off?
Please Help!
Thank You.
Antec 300w SL300S
Epox 8RDA3+PRO
AMD Athlon 2400+
256MB PC2100
128MB 8x AGP FX5200
Bad MOBO, Bad PSU?
Please Help!
Thank You.
