i have tested for like 20min small blend with prime95 and it seems to be stable.
looks like you're on your way to hit 4Ghz, just be sure to run for like 12 hours, I recently BSOD about 9 hours running prime and had to bump voltage up a couple of notches.
Sorry, I just don't agree that you have to pass a twelve hour long Prime95 test to consider you system stable. I mean, what if you had decided to run a 24 hour Prime95 test and you BSOD'd at 23 hr. Does that mean it's not stable?
well you don't HAVE TO do anything but I just don't want to BSOD from any circumstance
I agree with Trents here. I have always used 2 hours as my rule of thumb for stability, thanks to a suggestion from Trents when I was a new Oc'er. I wanted to see if my rigs were truly stable recently, some members have suggested that being able to run F@H 24/7 will really show if it is stable. So I ran F@H on the 3 rigs I have overclocked, My 8350 in my sig, my 955be @ 4.1 on air and my I5 2500k @ 4.8 on air for 5 days 24/7, None of them crashed. That is stable enough for me.I appreciate your thoroughness in seeking for true stability. We get no lack of excited new members who claim some wild overclock and then when we talk them into running Prime95 they come back with their tails between their legs. My contention has always been, however, that the length of the Prime test that needs to be passed before one can feel comfortable that stability has been achieved is at least somewhat dependent on what you will use the computer for and how mission critical the data is you will be working with. I think it is possible to put unnecessary wear and tear on the system with excessively stringent testing routines that will far exceed any demand made on the system in running real world apps.
I didn't run Intel burn either.Drake you mean you did not run P95 and Furmark at the same time? Woe is yore stability. Hehehe.
RGone...
