Hi guys,
Really stuck and need advice please!
I bought some components to try and build my brother's PC. Followed instructions but the general consensus was one of the components wasn't working properly.
I brought over some ram - didn't work so we ruled out that it was a memory issue.
So I took back his motherboard and processor and attempted to try his processor on my PC... you can tell where this is going.
I detached my heatsink and was careless - I yanked out my processor at the same time. No pins seem to have been affected, but the processor was stuck onto the heatsink whilst still locked in with the socket lever :/
So I then tried his processor on my motherboard - no luck.
I then tried my processor back into my motherboard - nothing.
So I tried my processor on his motherboard - no luck.
His processor, his motherboard - no luck.
Now when I use my processor/my motherboard, it boots but I can't turn it off by holding the power switch (don't know if this is significant?) - keeps running.
I can turn it off by holding the switch when using his processor/my motherboard.
I suspect:
His motherboard maybe broken, his processor fine
My processor broken, my motherboard fine?!
I think I've plugged everything back in:
ATX 20 pin, ATX 4 pin, 1 ram closest to processor, hard drive into Sata socket.
Tried resetting CMOS battery and took out graphics card, using onboard atm.
Have no idea what to do!
Any ideas?! Thanks in advance guys.
I suspect:
