- Dec 19, 2012
This is what I use for my loop which has ~ 40' of hose a big arse rad and about a six foot head. Not saying it would work for sure but it has a pretty god push to it. http://www.dannermfg.com/store/products/danner/pid-02517.aspx
You are not understanding what I am saying.I understand that there will be a breaking point on a fan running max all the time. But the Oil also keeps the fan well oiled.
Thanks for the input guys. yes I will keep the NH-D15 by Noctua in mind next time I want to upgrade something on the pc. Looks my problems are solved. I replaced the pump with an aquarium pump and that is flowing the oil now (a little noisy but I guess I have to put up with it). The cpu fan seems to do a longer spin once the temp of the oil goes higher. I also set the outlet of the cooled oil in front of the fan and that's seem to be enough. I finally had enough confidence to turn on the pc and test. when setting up windows and installing programs the temp is so low that I dint have the pump on. then installed Far Cry 4 and played it ( while the pump is on) temp seems to hang around 50~60 C. I think the limit would be 90C so its all good for now...Until summer is back!
I will post some pics for the finished product
Just out of curiosity does the mineral oil ever have to be drained and replaced?
There we go...Unless it's just the viscosity of the oil changing as the temps rise allowing the fan to spin with less resistance in the thinner oil.
By the way once I start gaming and the oil gets hotter the fan seems to perform better
Does a aquarium chiller have the capacity to keep CONSTANT heatloads, like a couple hundred watts, low?Have you thought of using an aquarium chiller to keep the oil temps low?
