- Dec 26, 2004
There have been many threads on how to help owners with 7000//7700 series coolers by Zalman... I am going to list a few methods here (ones I have done myself):
#1: Case Fan Direction:
This one is the easiest... Props to evaseeker for this one...
Well, normally, the zalman fan blows air ALL around it... thus blowing hot air down into the sink with a normal case fan config (front intake, rear exaust)... What evaseeker found was that it was better to have the rear fans blowing in... that way, the zalman gets cool air, and blows that down onto the heatsink, making cooling performance better... I have pictures showing what I mean:
This is a normal case airflow layout:
http://community.webshots.com/photo/329003831/345319175OXfqBU
With the zalman, that won't work out as well.. The rear fans will exaust hot air, but not as much as needed, and the zalman's fan will be sucking in hot air. So this is ideal:
http://community.webshots.com/photo/345319037/345319037ulPwLB
Also, if you have a BTX case configuration, it is much more optimal than an ATX config, as the CPU is on the bottom, and heat rises. So instead of having front intakes, you can a standard back-to-front airflow config.
#2: Zalman Fan Replacement:
Probably the most common zalman mod... The stock zalman fan is horribly slow... If you arent TOO much of a silence freak, get a new fan... it will benefit highly (Magick Man uses/used a 120mm fan with a spacer, and slips/slipped it over the actual sink)... With minor modding, you can get a 92mm fan, gut it leaving a few stubs, and then drilling 1/16" holes in the stubs... the screws from the stock zalman fan will self tap... Props to Navig for giving me a pretty in-depth 'tutorial' on this (shown here)...
my first fan replacement, a Panaflo 92mm High-Speed with RPM reading [FBA09A12H](56.8CFM): http://community.webshots.com/photo/335682843/281611839DNQfIs
http://community.webshots.com/photo/281612023/281612023gYdrJK
I didn't feel that the panaflo was enough, so I went a little beefier:
Delta 3-blade 92mm High-speed [EFB series](~80CFM... YIKES)... Same mounting as the Panaflo:
http://community.webshots.com/photo/329003831/345314849uBXgcK
http://community.webshots.com/photo/345314962/345314962EvWvyL
#3: Base Lapping:
Thx to EWBatOVAclockin for this one:
you might think the zalman base is flat... from what I've seen, it was far from it..
see what I mean?:http://community.webshots.com/photo/335682843/314475680ZLFSNO
lapped it up to 2000Grit (with a finish of printer paper), and its a charm now... look at the difference:
http://community.webshots.com/photo/335682843/339738851gXukdN
http://community.webshots.com/photo/339738936/339738936chJHov
and the moment of truth:
http://community.webshots.com/photo/339739088/339739088fYaGwN
I lowered my temps around 5 degrees after adding the delta and lapping my base (using ceramique) as compared to my unlapped base and the panaflo (using AS5)...
If you have any questions, feel free to PM, E~Mail or AIM me.
#3: Base Lapping:
