- Jan 9, 2006
This came up with RealMadrid, in another thread about GPU folding, but it needs a thread all it's own.
In general, it's been noted that a 4P system is better, because you can run it in 2P mode, and then when you are ready to upgrade, simply add the other cpu's, memory, and heatsinks. (Note that Windows is more picky about the cpu's it will run - they should have the same stepping and revision, and only Windows Server will recognize more than two cpu's).
With the QRB being such a big part of the points, a 4P rig is certainly a better than X 2 point producer, compared to a 2P folding rig with the same cpu's.
If however, 2P is the way you want to go, with a sense of frugality and an emphasis on folding power, here are some suggestions.
Please add your own suggestions.
Components for the 6174 2P Build:
Supermicro H8DGI-F-O EATX server $479.99 (has on-board video)
http://www.superbiiz.com/detail.php?name=MB-H8DGIF&c=CJ
cpu's: 6174 AMD Opterons, approx. $500.00
http://www.ebay.com/sch/i.html?_nkw=opteron+6174&_frs=1&_trksid=p3286.c0.m359
RAM: G.SKILL Ripjaws X Series 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7Q-8GBXH 2 x $59.99
http://www.newegg.com/Product/Produ...m1132X509988X71a288a48c4569017dde2a8491f4686c
HSF: Cooler Master 212+ 2 X $33.99 ea.
http://www.newegg.com/Product/Produ...=0&SummaryType=0&PageSize=10&SelectedRating=-
1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
LG Electronics GH24NS70B 24X SATA Super Multi DVD+/-RW Internal Drive (Black), Bulk w/o Software $18.49 (but see combo deal
directly below this, also)
http://www.superbiiz.com/query.php?...+24X+SATA+Super+Multi+DVD+/-RW+Internal+Drive
Case: - anything you like with good overall ventilation, and able to fit the Cooler Master hsf's AND an Extended ATX mobo.
Cooler Master HAF model 932, etc. is a popular choice. $139.99 (combo deal: dvd burner ends 3/31)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Hard Drive: Seagate Barracuda 160 GB $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148698
Power Supply: Corsair AX850 Modular, Gold efficiency, plenty of power, and great customer service and a long warranty. $189.99
http://www.newegg.com/Product/Produ...ark=&IsFeedbackTab=true&Page=2#scrollFullInfo
The people who handle Corsair's rebates are absolutely horrid - don't trust them, at all.
Small hardware pieces for the Hyper 212+ conversion to fit G34 (about $20)
Not included:
Monitor (not needed, after set up)
Keyboard (not needed after set up)
Mouse (not needed after set up)
Thermal Interface Material
To monitor the server's folding, you'll have the server data cable go to the same router you use. Now set up sharing on the
fah directory of the server. Use your regular FAH monitoring software, and it can "see" and report the folding progress.
I'm sure the above prices could be lowered somewhat, by thoughtful comparison shopping, etc.
Not included:
Code:
Summary:
479.99 mobo
1000.00 cpus
119.98 ram
67.98 hsfs
18.49 optical drive
139.99 case
74.99 hd
189.99 psu
20.00 misc hardware
$2,111.41 Sub Total
Tax
Shipping
Total
