I have three new 2Tb Hitachi drives. My plan is to run them using Unraid. Two are the 5300 Green drives and one is a 7200 drive. I was advised that having the slightly faster 7200 drive for the parity unit would speed things up a slightly.
My original plan was to use an older Abit IC7 Max3 motherboard with a 3.4 Ghz. That's a P4 Socket 478 processor. But the motherboard will only interface with two SATA drives. Secondly, UNRAID is designed to be run from a 4 Gb. Flash drive. The Abit board doesn't want to easily boot from that drive. It looks like there is a complex work-around that might allow it, but I want something simple.
I have a Core I5 2500K and an Asus P8P67 Rev. 3.1. But I've been having troubles getting them to play nice with one-another. So I'm looking for other options. (That's on the Memory Forum.)
All I want is a place to store backups of our three computers. I'm talking about mirror images AND in a separate process, saving the MyDocuments data files. I'll be using FBackup for the actual backup procedure. Then I want to offload the files to the NAS. I'll simply run this NAS on our network with a wired network cable to the router
I don't believe I need a high powered CPU to do this.
So some questions.
The Abit board won't work for my use. Is there another 478 board that would? That would allow me to use my 3.4 CPU and not have to buy another CPU? This CPU seems like it would have ample processing power for doing the tasks I have in mind.
The motherboard would need to support AT LEAST three SATA drives. An IDE interface would allow me to load drivers from my existing CD Drive, if needed.
I'm not wedded to any brand. I think most boards of this generation used DDR2 RAM. I have some of that. And I have a 500 watta power supply for this generation of boards. And I have a video card. I just need a motherboard with the right interfaces AND that will allow booting from a Flash drive.
I could get an inexpensive motherboard for the I5 CPU, but the processing power of this CPU looks like overkill for this kind of task. I figure I can do something else with this CPU.
Does anybody know a motherboard with the features I need?
Any and all input will be appreciated.
Bach On
So some questions.
Bach On
