- Sep 30, 2018
Hi all! I'm planning to build myself a computer desk, with all of the parts mounted under glass inside it. After the aftermarket arctic gpu closed loop cooler developed a bubble in the pump and toasted my r290, I decided it was time to take matters into my own hands and build my own custom loop. Then a coworker mentioned that folks have built this kind of thing, and sent me some youtube links... I mean, I like my define r5 and all, but no tower seems like a way better solution. Plus, they look really cool.
Anyway, I spent the better part of September researching what's needed, parts, power, and other juicy tidbits to put it all together, and I've hit a small snag. I can't seem to find reservoirs to fit what i want to do. I was planning to do a "silo" approach with short vertical tube reservoirs, but the widest I've found is 80mm from koolance, and those would still be too tall for me to remote a fill tube outside the 'case'. Here's a mock-up of the component layout. The desk will be 22"x46" when finished.
Rads will be 140x280, pump will be dual d5's mounted to a single top, and i already have blocks for the cpu/mosfets and gpu.
So, I'm looking for (maybe) 120mm wide reservoirs, and I need to know if the pump should be 'gravity-fed'. Can I put a fill tube anywhere in the loop, or should it feed directly into the res? It just seems to me that mounting the res horizontally would make draining the system an ordeal.
