Moving over the stator guide vanes, the fan blades create pressure pulses. This type of rotor-stator interaction significantly contributes to the fan’s overall noise emission. With a uniform distribution of the stator vanes, the relative geometrical constellation of the rotor blades and the stator guide vanes is identical each time the rotor moves over the next stator vane. This means that each time a stator vane is passed by a rotor blade, the same pressure pulses are created. Acoustically, these periodic pulses lead to noises at distinct frequencies and manifest themselves as frequency spikes in the fan’s acoustic spectrum, giving it a more tonal and distinguishable character. To avoid this phenomenon, the NF-F12’s stator guide vanes are set out in Varying Angular Distance (between 31° and 37°). Due to this measure, the geometrical situation between the rotor and the stator parts is slightly different each time the rotor moves over the next stator vane, which results in aerodynamically different pressure pulses and hence spreads the noise emission over a broader frequency range. Producing a less tonal and more broadband acoustic profile, the VAD stator guide vanes make the fan more agreeable to the human ear and let it blend into the background noise more easily.
