- Jun 28, 2002
- Phoenix, AZ USA
ACK! I meant swamp (as they are sometimes called)/evaporative cooling.
Evaporative cooling would rock for getting temps down if there were a way to pass air through some kind of unit without the water squirting out all over the place.
Is there anyway to keep watter in a rad like unit with a couple of fans strapped to it OR is there any type of membrane that would allow sufficient airflow through it to cool the water while still holding in the water? Sort of like dialysis tubing is permiable to certain liquids, is there a thin layer membrane that would allow for some air cooling of the water?
Do bong setups de-pressurize when running through the bong and then some how re-pressurize?
Thanks for any input!
