Do you have the latest bios installed for your motherboard? Go to the manfacturer website and check which is the latest version available. Then download a freeware program called "CPU-z" and install it. If you check under the "Motherboard" tab of the program user interface it will tell you what bios version you have installed. If there is a later one available, you can "flash" the bios. It might help. No guarantee, however. I would assume that instructions on how to flash the bios would come bundled with the new bios file.
