Hi
I have this Radeon RX 480 which I never got working because if I try to view videos or play games in fullscreen it makes the system freeze and then boot and sometimes display gray static...
Any ideas what I could try to fix this?
I have installed newest mobo bios and tried with older and never (GPU) drivers
Here's my full system specs:
GPU: Sapphire Radeon RX 480 Nitro+ 4GB 2xHDMI, 2xDP, DVI
CPU: Core i7 2600K, LGA1155, 3.4 GHz, 8MB
HD: 120GB Vertex 2 Series SSD
RAM: HyperX 2x4GB, DDR3 1600MHz, CL9
Mobo: P8P67 LE, Rev 3.0, LGA 1155, Intel P67, DDR3, ATX
OS: Windows 7 Home premium 64bit
Note: I used to have HD 6870 on this same machine and it worked fine... which is why I believe the problem is with the new GPU
thx!
thx!
